Tried to make a fuel pressure gauge
Old Aug 22, 2007 | 10:02 PM
Hammily's Avatar
I was trying to follow Infidels advice on how to make a fuel pressure gauge but without success thus far. My wife was watching the gauge in the cab while I was opening the needle valve. She said it made a small twinge and then didn't move again while I was slowly opening the valve. I also had a leak in the cab by the gauge. I only tightened the nut 1/2 turn past finger tight as per instructions I tightened it a little further after I noticed it was leaking only to make it leak faster. So I took it apart and only tightened it 1/4 turn past hand tight. Leaked again slowly tightened it more seemed to stop but over a little time started again. The gauge is for oil press it never worked so I guess I will try another gauge tomorrow. Anybody else make one of these work?
John
Old Aug 22, 2007 | 11:17 PM
wcbcruzer's Avatar
You really don't open the needle valve that much. Like 2mm from full close.
Old Aug 23, 2007 | 12:11 AM
leprechaun's Avatar
I followed Infidel's post about installing a fuel pressure gauge and it came out well.I used a water pressure gauge but it shouldn't make any difference.I also had a small leak in the connection at the gauge so I cut the old ferrel off and installed a new one and that took care of it.
Old Aug 23, 2007 | 10:18 AM
infidel's Avatar
Shelley's advice is right on, replace the ferrel.
The ferrels tend to get distorted and don't usually seal with retorquing.
As for no pressure reading, I would suspect that either the gauge or your overflow valve is bad. Or could be that the leak is venting all your pressure.
Old Aug 23, 2007 | 10:38 PM
Hammily's Avatar
New gauge, new ferrel. No leaks and this gauge works. I have about 10 psi at idle and by the time I am going 45mph it has gradually gone down to 0 psi. Is my lift pump bad?
John
Old Aug 24, 2007 | 06:31 AM
Txwelder's Avatar
Mine leaks at the banjo bolt. What is the best sealant?
Old Aug 24, 2007 | 08:18 AM
patdaly's Avatar
John
Pinch the return fuel line behind the fuel filter, if your pressure does not come up, probably the Lift Pump, fuel pre-filter, or fuel filter. If it does come up, probably your overflow valve on the P7100.
Should be 20-25 at idle and 35 or so at speed, IIRC.
Old Aug 24, 2007 | 10:02 AM
infidel's Avatar
Permatex #2 or anti-seize.
Old Aug 24, 2007 | 12:46 PM
Txwelder's Avatar
I used grey anti-seize and it leaks, will try the permatex.
Old Aug 25, 2007 | 08:32 PM
Hammily's Avatar
Pinched the return line and at idle the fuel pressure got up to 50 psi in about 10 seconds and was rising quickly so I shut down the engine. So I guess it's time for a new overflow valve. Thanks for your help guys.
John
dodgeguy71
17
Jan 19, 2012 12:52 AM
jmccart
Apr 13, 2007 11:43 AM
Patriot_RAM
Oct 8, 2004 06:10 PM
Bobp
Mar 14, 2003 05:52 AM
