Transmission fit?
I have a 1994 3500 4x4 with a cummins and the transmission gave up the race! Will a transmission from a 1996 2500 4x4 with a v-10 in it match up? Do I need a different TC for the diesel? The 96 has 140 000 miles - is it worth taking a chance on it?
Thanks for your thoughts and information.
Need to make sure its an RH model like yours, I think in 96 they may have had RE and RH models. RE uses computer to regulate pressures and your RH is just mechanical governor in the trans.
Other then that, yes torque converter would be in your interest to change, along with probably a shift kit for a diesel to get pressures up and and get shift points back down for diesel as well.
Thanks!
Thank you to those who saved me from buying a truck that would have been another flower pot in the back yard! I guess I have to keep searching. I really appreciate this forum and the time you guys take to help others!
Dauntless
15
Aug 30, 2016 08:37 PM
