Transfer Case Questions!!!!!!
Old Dec 18, 2007 | 04:53 AM
part time pulle's Avatar
Will a transfer case out of an auto work on a 5sp or do you have to change the input shaft??? Also are the input/output shaft on a DLD the same on DHD??? I need a couple cases but the ones I have found are out of an auto and I just want to be sure they will bolt up before I spend $$$$
Old Dec 21, 2007 | 08:21 AM
stirpicult's Avatar
https://www.dieseltruckresource.com/...ht=manual+swap
"5. The manual output shaft is a larger 29 spline, and your auto uses a smaller 23 spline. You'll have to order a new input gear for the Tcase. Again, this is not a hard install, but the Tcase must be mostly disassembled to get access. There is no rocket science inside, I did the conversion in about an hour."
wyododge
Aug 18, 2011 07:48 AM
lews930
Mar 3, 2009 05:51 AM
boiler-rat
Oct 10, 2006 10:28 PM
MR HYDROSEED
Jun 8, 2006 07:42 PM
