trans temp ?
Old Feb 6, 2005 | 01:52 PM
John Faughn's Avatar
trans temp ?
I asked a while back about temp sensor adding to trans ,I had found a sensor in the cooling line near the pan some one ansewred back that they thought that the last owner did a mod but there is a temp lite on the dash so that makes it stock , so now what I am wandering is can I get a sensor and gage to work in that fitting .
Old Feb 6, 2005 | 04:57 PM
bmoeller's Avatar
Since you have a '94 (47RH tranny), you won't be able to use ithat fitting for a temp gauge. The PCM uses it to turn the idiot light on, and to know if the oil is warm enough to go into O/D during the winter. Won't shift into O/D 'til about 20* or so. That line on the 47RE, doesn't come with the port. I added one to mine, for a gauge.
On the RH, the sender goes into one of the test ports on the tranny, or in the pan.
Old Feb 6, 2005 | 06:16 PM
infidel's Avatar
You should put your new sensor in the stock port. The port is 3/8" so you'll probably need a 3/8"x1/8" bushing. You will have to jump the wires that used to go to the stock sender with a 1000 ohm resistor (Radio Shack 25¢) to fool the PCM into reading normal tranny temp.
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
