trans question
Old Nov 6, 2006 | 08:28 PM
jmkennemur's Avatar
trans question
hey guys i appreciate any help anyone can give. i have a 97 ctd automatic.
the trans takes a while to shift from first to second, then immediatly shifts to third, also at highway speed will not kick down to accellerate. any suggestions would be appreciated.
Old Nov 6, 2006 | 08:47 PM
dslpower's Avatar
Check the throttle valve cable adjustment, one end is connected to throttle linkage at the bellcrank assy. Other end goes to a lever on the tranny, when the throttle moves so should the lever on the tranny.
It has a push button slide adjustment on it, but you need a buddy to mash the go pedal while you look at the lever to make it right.
Old Nov 7, 2006 | 07:01 PM
jmkennemur's Avatar
is the adjustment at the bell crank or the trans? i looked but did not see where to adjust it. i may just have missed it. i did not see it at the bell crank. also, how do you properly adjust it?
Old Nov 7, 2006 | 07:03 PM
dslpower's Avatar
Its at the bellcrank end, the pushbutton may or may not be visible depending on how it was installed.
Adjust it so there is no slack on the inner wire to start with, then with the help of a buddy have him slowly mash the throttle while you look at the lever on the trans. Lever on trans should move instantly with the throttle.
Old Nov 15, 2006 | 03:49 PM
jmkennemur's Avatar
thanks for the help. found cable to be frayed at top where it goes into the sleeve. am looking for a new cable.
Old Nov 15, 2006 | 06:44 PM
dslpower's Avatar
I have one that came off a V10. Not sure its the same though, will have to go look and see. Its raining here so it might be a bit before I can go check.
You can have it for the cost of shipping to your zcode, I got it xtra with a cruise servo i bought.
Edit... went out and looked, it looks the same to me. Same connectors on each end, but i did not measure the length.
nvr-enuf
May 10, 2011 02:49 PM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
