Trans interchangability
Old Oct 30, 2009 | 12:54 PM
b.lee's Avatar
The auto transmissions from a 96 2500 ctd 4x4 and a 98 2500 4x4 ctd are the same right?
I just need to make sure before buying this trans tomorrow.
It's a trans from a 98, I'll be putting it in my 96
Sorry for the lame question, I tried searching, I'm not the greatest searcher, plus I'm at work and have limited time.
Thanks
Old Oct 30, 2009 | 04:54 PM
patdaly's Avatar
Close to the switch, sorry don't know for sure, I do know the trans filter is different. I do know you can make it work, something about the trans temp circuit needing a resistor.
For some reason I thought the switch was tho 2000 MY.
Old Oct 30, 2009 | 05:54 PM
b.lee's Avatar
What does 'tho 2000 MY' mean?
thx
Anyone other trans guru's help me out please.
Leaving at 2:00am tomorrow morning to get the trans.
Old Oct 30, 2009 | 06:53 PM
sjester's Avatar
MY = model year
Old Oct 30, 2009 | 07:37 PM
infidel's Avatar
Both trannys are 47RH and will swap right over.
Only thing that might be different is the electrical connector.
Old Oct 31, 2009 | 06:12 AM
RPegram's Avatar
I believe they may both be 47RE. In '96 the move to electronic governers was made and both should have internal thermistors located inside of the pressure sensor. Someone corrected me on this yesterday, so I had to read up on it.
Old Oct 31, 2009 | 06:59 AM
infidel's Avatar
Yep. you're right, brain fart, it's an RE
Old Nov 1, 2009 | 08:35 AM
b.lee's Avatar
Your the man infidel
How can I switch over the electrical connector?
Will I need the connector from the 98 truck? Or is there some mod that can be done?
ryan10
Oct 30, 2009 10:40 AM
NorthWestMatt
Apr 17, 2009 06:37 AM
YJim
Feb 18, 2009 11:50 PM
KAyers
Oct 25, 2006 01:47 PM
subs1000w
Aug 20, 2004 02:12 PM
