tranny line fix?
tranny line fix?
Ok, I got 1 of my tranny lines off of the main cooler, under the turbo, start to leak! the 2 lines rubed together and rubed a hole in 1 of the lines. Whats the best way to fix? can I splice the line with compression fittings? I really do not want to buy another line,but if I have to, can I just make one? flared ends? any help would be great guys, thanks, shawn
Here's some more applicable stuff too. https://www.dieseltruckresource.com/...threadid=56519
Shawn, you could use hydraulic line, or, what I did was ordered 25 ft. of aluminum line from Summit Racing for a good deal. Then I bought one of those spring tubing benders for about 5 bucks. My biggest tubing bender went up to 3/8", so the spring bender worked fine. I got them bent up pretty close, they work just fine. Make sure and save the old fittings so that you can re use them later. Use 1/2" line and flare it up. It took me about an hour to bend up and install 2 lines.
jimnod22
08-26-2012 02:32 PM
Lester
01-29-2005 11:16 PM
