5 Speed Lube?
Old Apr 25, 2005 | 02:11 PM
nitrousn's Avatar
5 Speed Lube?
I am thinking that i should change my 5 speeds gear oil in my95 3500 4X4. Looking for suggestions as to what would be best. I was thinking of going synthetic. Any help would be great. Thanks in advance.
Old Apr 25, 2005 | 04:32 PM
Lil Dog's Avatar
Stick with the OEM oil.
Do a search on the NV 4500 and you will find alot of different posts on oil. The only oil that goes into that transmission is right on the tag. The MOPAR oil is Castrol Syntorq NOT SYNTEC. It is a specially formulated oil for the syncro's and bushings in the tranny.
Some guys use AMSOIL with good results also.
For me I stuck with the OEM stuff.
J-eh
Old Apr 25, 2005 | 05:05 PM
apache's Avatar
Yes, Syntorque can be had at Chevy dealers also. different bottle,same stuff for $24 a quart as opposed to $32+ at Dodge. One of the vendors here? sells it per gallon for $60? or so. I also talked with Redline and they say a 50/50 mix of thier MTL and 90wt gear works? no guarantee though. The deal is as I read is the dodge syncros are carbonfiber I think and the additives in GL5 rated oil will eat them up. The syntorque is GL4. The oil is rated as a "lifepack"?
Old Apr 25, 2005 | 06:18 PM
infidel's Avatar
I would only use Syntorq. Best price, $13.50/qt, bottom of this page
http://www.standardtransmission.com/dodge.html
Old Apr 25, 2005 | 08:02 PM
nitrousn's Avatar
thanks for the replies. any idea on how many quarts i need to have on a drain and refill?
Old Apr 25, 2005 | 10:29 PM
apache's Avatar
If I remember correctly mine took 4 quarts.
Old Apr 26, 2005 | 01:17 AM
argve's Avatar
"lifepack" as in doesn't need changed...
Old Apr 26, 2005 | 10:09 AM
apache's Avatar
Thats what they say, but if its anything like my 95 the trans oil will get changed regulary everytime it craters, 3 times in 130K for me.
Old Apr 26, 2005 | 12:25 PM
nitrousn's Avatar
""lifepack" as in doesn't need changed..."
________________________________
care to explain what lifepack means??
Old Apr 26, 2005 | 01:33 PM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
AMSOIL 120K flawless miles..........porven product but to each theyre own
Old Apr 26, 2005 | 06:39 PM
argve's Avatar
I'm just not sure I buy into the whole "lifepack" thing... Something in me say the fluid needs changed. I mean if your working the truck pulling a load (like most of us do) then there has to be something in the fluid that breaks down then is no longer usable... Humm which reminds me I have not changed mine yet and I don't know when the last time it was changed (purchased used last fall with 177k on the ticker)...
Old Apr 27, 2005 | 08:01 PM
doug60's Avatar
I have been running Lucas oil stabilizer / lucas 75 /90 . 50 / 50 mix. for over 100,000 miles . Trans, rear, & transfercase. Truck still gets 19 miles per gallon. Change every 35,000 miles.
Old Apr 28, 2005 | 10:05 AM
infidel's Avatar
I think when they say lubed for life it's under the assumption that most folks only keep their rigs for around 100k miles. The tranny lube should be good for a very long time though since it's not contaminated by products of combustion like motor oil and rarely will reach temps high enough to alter it especially since the recommended fluid is synthetic.
Heck I have the same tranny fluid in my '82 Toyota PU as it had when it came off the dealer's lot 320k ago. Of course it's never towed anything though.
mknittle
Mar 11, 2015 10:47 AM
dssimecek
Mar 10, 2008 04:58 PM
RAFTEN
May 28, 2007 09:40 AM
Hoss
Apr 20, 2005 09:24 PM
KC
Jan 10, 2003 11:25 PM
