Six Speed Lube
Old May 28, 2007 | 12:07 AM
RAFTEN's Avatar
Six Speed Lube
I know the answer to this is already in here but I can't find the post. Someone posted that Auto Zone has/had the correct lube on sale for $6.50/qt. I need to know the name of the lube so I can go check my local Auto Zone. Also, I plan to remove the PTO cover to drain and clean the magnet. Put it back on with black sealant and add 5 qts. Sound about right? Haven't quite figured out how to add the lube thru the top PTO hole but I imagine it will become clear once I get going on it.
Old May 28, 2007 | 09:40 AM
johnh's Avatar
valvoline manual transmission lube, i have used it before... it's the same as the oil you get from the dealer. i think it's a synthetic
put it in the top of the trans, it is easy to remove the plastic consol and the shift tower
mknittle
Mar 11, 2015 10:47 AM
dssimecek
Mar 10, 2008 04:58 PM
PITBULL
Jan 20, 2005 09:18 PM
RacerX
Apr 13, 2003 02:07 PM
prairieguy
Feb 24, 2003 02:07 PM
