too much smoke
Old Jan 12, 2005 | 04:46 PM
MY WORLD's Avatar
too much smoke
I switched to a HTT 35/40 turbo. It ran good. I went to DD3's to better utilize the turbo increase.
Now I have way too much fuel till about 1800 rpm. Then put your head back against the seat.
I moved the star wheel back from full on, but that didn't help.
Should I change the turbo to a bigger one [htb2] ?
Any suggestions appreciated!
Wayne
Old Jan 12, 2005 | 05:01 PM
gunracer1's Avatar
slide the afc housing all the way to the rear. a bigger turbo will make more bottom end smoke
Old Jan 12, 2005 | 06:31 PM
Forrest Nearing's Avatar
yup, you've got less air at lower RPM now w/ the bigger turbo... tighten up that AFC.
or just leave it smokey
Old Jan 12, 2005 | 08:27 PM
TxDiesel007's Avatar
Since when is too much smoke a bad thing?
you need more air to spin the bigger turbine in the turbo, which only creates more smoke when u get on it tryin to spin that turbine.. Dunno much bout the AFC, or what it is for that matter, but simple physics seemed to work for me before i read the rest of the replies....
the thing i learn in school...
TxDiesel007
Old Jan 12, 2005 | 09:26 PM
AFC = Air Fuel Control
basicly it dictates how much boost is required to move the fuel lever arm forward...
looser = more fuel, more smoke, and more heat which spools the turbo up quicker (to a point)
tighter = less fuel, less smoke, and slower turbo spool up
if you haven't adjusted your AFC, you REALLY should!
Forrest
Old Jan 13, 2005 | 09:30 AM
infidel's Avatar
I definitely wouldn't slide it all the way back to start, it will probably turn gutless.
Try halfway back first and go from there.
Old Jan 13, 2005 | 10:05 AM
don't slide the housing back, just tighten up the wheel.
Old Jan 13, 2005 | 10:43 AM
CTD NUT's Avatar
I agree, sliding the housing back could limit WOT fueling......and we don't want that!
tightening the spring tension will slow down the boost enrichment some without limiting ultimate fueling!........you should be able to find a happy medium........
Old Jan 15, 2005 | 08:01 PM
1dslram's Avatar
The #10 plate will help as it flows less fuel than the #4 on the lower end. You can also add the heavy spring to the AFC to slow low end fueling. Adding a Valet switch will also help low end smoke. Double the amount of diesel fuel additive that you use.
Bruce
dieselJon
Jan 3, 2011 08:18 PM
jjrightmire1973
Nov 20, 2008 08:20 AM
pjram2002
Jul 8, 2003 03:55 PM
Wes C
Dec 24, 2002 12:28 AM
csaverline
Dec 8, 2002 07:18 PM
