timing pin
Old Jun 7, 2005 | 11:10 PM
plow's Avatar
timing pin
if the timing pin engages does that mean that engine is at btdc no matter which way you turn engine. i have no barring tool so i just turn alternater pully turning engine backwards.
Old Jun 8, 2005 | 12:15 AM
Hemi Cat's Avatar
It is TDC on cyl 1, either valve over lap or compression firing. When you check or set timing you are supposed to turn the eng in normal engine rotation to keep the gear back lash tight. Try useing a 15 mm socket and ratchet on the front pulley bolts. It's a pain but will work.
Old Jun 8, 2005 | 06:51 AM
Stamey's Avatar
When the timing pin goes in it is TDC on number 1 compression stroke. This is because the pin goes into the cam, not the crank. If it went into the crank there would be a possibility of being 180 degrees out.
Remove backlash as advised above.
Chris
Cowboy_Customs
Oct 18, 2011 01:46 AM
mechmagcn
Oct 12, 2011 10:29 AM
West Coast
May 26, 2007 10:22 PM
bigragu
Oct 17, 2005 04:07 PM
Crimedog
Mar 11, 2004 01:54 PM
