timing- again
Old Jan 11, 2008 | 02:54 PM
Ru rammin 2?'s Avatar
timing- again
noone around here has a socket to pull the delivery valve off. anyone have any part#s I can go off of or any other suggestions?
Old Jan 11, 2008 | 03:42 PM
dieselman2300's Avatar
TST and Piers sells them for $35.
Did you get a dial indicator?
Pure diesel power also sells them.
Old Jan 11, 2008 | 05:10 PM
I have access to a dial indicator but I need the socket. If I could get a website I could get a part# and maybe cross reference it I could keep my business local and help out some of the local boys.
Old Jan 11, 2008 | 06:19 PM
Snapon PART # is sp503. $41.50. If you have a local guy that runs around with a snapon truck he can get it.
Old Jan 11, 2008 | 06:20 PM
Tate's Avatar
Got a Snap On dealer? Its about $45 through them.
Do you have a barring tool? Do you have the holder for the dial? Mag base might work, but there is a lot of non-ferrous metal around the pump, and the iron pieces don't always have a flat surface to mount the base.
Old Jan 11, 2008 | 06:24 PM
No I don't have the holder but I would buy that too if I could get the number to cross over. Im not sure I would try a mag base on that, rather do it once. I have a SO dealer but he's an A*& hole.
Old Jan 11, 2008 | 06:28 PM
Tate's Avatar
Get a drain plug from an oil pan (M20x1.5 threads, I believe), drill out the center and put a set screw in the side, and you can mount the dial in that. 1" dial fits perfectly.
Old Jan 11, 2008 | 06:47 PM
K. Ill try that maybe. how much are real holders? where can I find one?
Old Jan 11, 2008 | 07:03 PM
Snap-On. Maybe a Bosch dealer.
You can order everthing from snapon.com if you dont want to deal with the snapon guy.
Old Jan 11, 2008 | 09:22 PM
Fueling around's Avatar
I believe a complete timing kit is actually made by Miller or SPX Miller, one of the largest specialty tool companies. A kit includes the socket, barring adapter, dial indicator & base. About $250 if memory serves. A good source for these is through a Case-International-New Holland dealer.
Old Jan 11, 2008 | 09:57 PM
Im pretty sure miller doesnt make it anymore. Thats just what I heard when I was looking for one.
Steven K
Jun 4, 2009 10:32 AM
b84u
Feb 20, 2006 01:04 PM
chuck3
Feb 1, 2005 07:47 AM
gunracer1
18
Nov 24, 2003 08:56 AM
Sean S
Nov 15, 2002 12:25 PM
