throttle stuck
Old Apr 25, 2005 | 05:37 AM
studebaker's Avatar
throttle stuck
I was going down the Florida turnpike Saturday and turned my cruise control off as I was coming up to the exit I was looking for. Well, the truck just kept running like the cruise was still on. I managed to stop on the exit shoulder and started checking the cables that run from the cruise to the throttle lever. Everything checked out but my throttle still wouldn't come back to idle. I finally discovered that the throttle rod (long rod with a z shape) had rolled over and the z portion was sticking up against the intake manifold which prevented it from returning to idle when the pedal was let up. It did the same thing one more time before I got back home in Lake City Fl. Could the little socket joints be worn and causing this as I see nothing else ?
thanks guys-
Old Apr 25, 2005 | 08:24 AM
BoostdCTD's Avatar
It is quite a common problem.
# Worn throttle rod parts - photos parts diagram
* Symptoms: Throttle binding, high idle speed, loss of throttle control
* Temporary fix: Use tape or a tie-wrap to keep the socket on the ballstud.
http://dodgeram.org/tech/dsl/trouble...2v_trouble.htm
Old Apr 25, 2005 | 11:12 PM
Hemi Cat's Avatar
Sounds like the lock nuts are loose. Adjust it and tighten up both lock nuts
Old Apr 26, 2005 | 12:03 PM
studebaker's Avatar
Lock nuts
Actually it was the lock nuts loose. Even with them tightened up it still rolled way to easy to I went ahead and replaced the rod with ends (dodge doesn't sell just the ends now) and everything is hunky dorey !!
Thanks guys--- you came thru again
Old Apr 30, 2005 | 08:15 AM
Twisted Shifter's Avatar
I have a really stupid question .... if the truck is 11 years old and they never did the recall, do you think I could get it covered?
Old Apr 30, 2005 | 08:35 AM
Forrest Nearing's Avatar
happened to me a couple days after I got my truck... kinda scarry w/ that Cummins pushing back!!
loose locknuts allowed the throttle shaft to rotate over and bind up
Old Apr 30, 2005 | 10:00 AM
Sidewinder's Avatar
I think that if it is/was a safety issue there is no time limit. I had 7 recalls done on my '95 last year. The previous owner must have ignored all of them.
Old Apr 30, 2005 | 12:03 PM
Cool I will call the dealer on Monday and have them run the VIN thanks .......
Old Apr 30, 2005 | 04:59 PM
infidel's Avatar
Recalls are free no matter how old the vehicle is or how many owners it's had
You can check for yourself here
http://www.dodge.com/webselfservice/...m%28%27R%27%29
Old May 2, 2005 | 09:47 AM
Bummer ... it comes back clean .... but then I guess that could be a good thing .... the people got the recalls done atleast
Old May 2, 2005 | 06:09 PM
fschiola's Avatar
This just reminded me to check for the recall on my 1997's throttle. It wasen't done and the dealership has the parts to do it tommorrow. They told me there would be no charge.
Old Sep 3, 2006 | 05:12 PM
Dave88LX's Avatar
None, bummer.
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
04ctd
Sep 14, 2004 04:43 PM
christinyou
Feb 7, 2003 09:32 AM
