Stuck ujoint
Old Sep 2, 2006 | 02:05 PM
pitr's Avatar
Stuck ujoint
Sorry about the crappy picture, all I had was my cell phone.
I had to pull the axle shaft out (passanger side) to get the joints off, is there anything special I need to worry about when I put it back in? Do i need to replace the seal on the far passanger end of the axle disconect?
Can I pull the driver side out as well or should I figure out how to get the press on there with the shaft in the truck?
Now for the really fun part. What I am holding in my hand is the top of the end cap. It shot off at around 500mph leaving the bulk of the cap still suck in the axle half. Funfun. I think i am going to take a die grinder to it to split it then try and peel it off the inside of the shaft. Any better ideas?
The other cap in the picture is from the far side of that same joint. The needle berrings where gone. No idea how they got out, but I am sure that had _nothing_ to do with the failure of the joint.
Old Sep 2, 2006 | 02:13 PM
Baja's Avatar
If you have the time, try to soak it in something like PB Blaster or ?, then take a socket start the beating process. I have done it that way, but if all fails, the die grinder will work as a last resort. Good luck.
Old Sep 2, 2006 | 02:17 PM
pitr's Avatar
All that liquid sitting on it is a ton-o-pb blaster :-)
Old Sep 2, 2006 | 03:06 PM
Baja's Avatar
Well, I guess that you are one step in front of me, not the first time that has happened . Have a beer or three, and start step 2 if you haven't done it already. Looks like nobody else has chimed in.
You definitely have the telltale marks on your hand that you work on trucks!
Old Sep 2, 2006 | 03:56 PM
Clayten's Avatar
DTR's Toad Wrangler
You might try to run a beed of weld on the inside of the stuck part. Then let it cool and it should come out. This will make it shrink I have done this with bearing races.
Old Sep 2, 2006 | 03:57 PM
pitr's Avatar
Well, i got that stupid ujoint end out. Turns out a correct sized socket and the air chisel will do the trick. The socket didnt really survive, added it to the pile of about 7 sockets that need to go back to sears that have been wrecked in this project. Ever notice impact sockets dont tend to break so much as blow up when they fail :-)
Still need to figure out if there are any gotchas in putting the axle shafts back in.
Btw, my kingdom for a sand blast chamber. I need to find some good way to clean all this crap before putting it all back together.
Old Sep 2, 2006 | 03:58 PM
pitr's Avatar
I got it out, but that is a really great idea! Certainly file that for later use.
Old Sep 3, 2006 | 12:45 PM
pitr's Avatar
Anyone? Do i just clean the axle shafts off and push them back in?
Old Sep 3, 2006 | 08:55 PM
bmoeller's Avatar
Check for any nicks or burrs on the shaft, before sliding it in. Will ruin the seal other-wise.
I've used the torch to cut the caps out before. Just have to be careful.
Baja
Jan 29, 2008 08:17 PM
joeel
Apr 4, 2007 08:27 PM
lucey
Oct 26, 2006 06:47 PM
TrxR
Apr 15, 2006 09:18 AM
jaconst
Apr 7, 2006 10:45 PM
