Thermostat Fluctuating
truck gets up to around 190 then just drops randomly then goes back up all within a few seconds...do i need a new thermostat?? ive heard of people putting different ones in???
What you are experiencing is normal. This scare a lot of people but there is nothing wrong. All you are seeing is the thermostat opening and closing. When it opens, the cold air from the radiator enters and causes the drop. They eventually relocated the sender to decrease the number of complaints about it.
It is a really big cooling system and they put the temp sensor way in back. What you see is a slug of cooler water coming through when the thermostat opens. They moved the sensor on later years to stop most of the fluctuation.
Bookshelf
May 30, 2009 01:17 AM
CIN'S DODGE
Nov 20, 2005 09:39 AM
barracuda
May 19, 2004 03:44 PM
