changing pick-up hose in tank
Old May 23, 2009 | 09:44 AM
alaskanassassin's Avatar
My dad has a 94 12V and when he pushes the primer he gets nothing coming to the filter housing. I suggested he check his hoses in the tank. What is the easiest way to check it? Drop the tank or lift the bed. Thanks
Old May 23, 2009 | 10:27 AM
Dr. Evil's Avatar
Unless you have a engine crane and lots of room I would drop the tank. If the truck runs, I would run the tank down as far as possible and use a flllorjack and a good chunk of lumber or ratchet straps to lower it.
Old May 23, 2009 | 11:29 AM
infidel's Avatar
If you have some spare hands, a beam, tree branch, etc tilting the bed is easiest.
Remove the four bolts on the driver's side, loosen the four on the passenger.
disconnect the fuel fill and vent hoses, watch out for any wires.
Two people can lift one side while a third props it up.
You only need about 18" of clearance to get at the tank.
Advantages to tilting are the tank doesn't need to be almost empty, you can see what you're doing disconnecting the hoses and wiring and you avoid having the tank straps break when you bend them apart to drop the tank.
MAC702
Mar 4, 2013 12:44 PM
Ole JIM
Mar 12, 2007 11:23 PM
Brad02ctd
Apr 28, 2006 02:47 PM
george7941
Aug 10, 2005 07:06 PM
Mike Holmen
Feb 1, 2004 05:21 PM
