Temporary stall from dead stop
Old Dec 30, 2009 | 09:01 AM
rodney cantrell's Avatar
haven't had my 95 Dodge long and I don't know if it's been modified. I haven't been into it yet, but I devoleped a transmission line leak and had that repaired and filter changed, bands adjusted. From dead stop and hit it hard it has a momentary stall, almost like not enough fuel, but then goes very well. Any ideas.
Old Dec 30, 2009 | 10:00 AM
infidel's Avatar
Could be the idle is too low, follow instructions here> http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Old Dec 30, 2009 | 08:59 PM
lifer's Avatar
sounds like normal turbo lag. If you nail it from a stop the exhaust pressure must build to make the turbo spool up. If you roll the throttle on it will not do it.
Old Dec 31, 2009 | 04:21 PM
lifer's Avatar
It could also be a bad overflow valve on the injection pump.
flyingd
17
Jul 11, 2017 11:13 AM
PaulDaisy
Aug 14, 2009 10:52 AM
Justinlhc
Oct 3, 2008 06:53 AM
royta
Nov 6, 2006 08:19 AM
JD730
Aug 2, 2005 11:33 AM
