TC Unlocking Under 40 degrees
I have a 1995 Dodge Ram 2500 with 312,000 miles and whenever the temperature is below about 40 degrees Farenheit the torque convertor will unlock and lock back up. However when the temperature is above 40 degrees it does not do it at all. Does anybody have any ideas why it would be temperature related?
My owners manual said the converter wouldn't lock until the trans reach 40 degrees. I found out that most of my trouble was from the throttle position sensor being dirty inside. Got to assume the dirty TPS was confusing the computer because, as soon as I changed it, everything was back to normal. There's a way to clean the TPS but, I've never done it, maybe try a search for TPS cleaning.
Your tranny temp sensor may be acting up. Easy way to check it is to unplug the cable to the sensor and jump across the wires to the PCM with a 1000 ohm resistor- Radio Shack 25¢. The sensor is located on the hot line to the cooler, driver's side a little forward of the tranny.
If the resistor does the trick sender is the problem. Replace the sender or just leave the resistor in place.
I've been assured by a couple of tranny gurus that not having an operational sensor will not hurt the tranny in the cold but you should have a sender that works or an aftermarket gauge to warn of high temps.
Originally Posted by got...DIESEL?
if it is to do with the temp circuit, OD should also be affected, and I believe my DC manual calls 59* the magic number.
dieselnewb
Sep 6, 2014 09:53 PM
abc4yew
15
Aug 18, 2006 11:10 PM
olivmatt
Dec 19, 2003 07:00 AM
hellotbone
May 7, 2003 10:25 AM
