1998 Dodge Ram 2500 trouble starting under 70 degrees
Having trouble starting at any temperature under 70. I have no idea what it could be, please help. A little background on the truck. I inherited it a little over a year ago. 94000 miles, new batteries,runs great other than the cold start problem. Any suggestions would be greatly appreciated.
Yep, that first, then if it is still an issue, try and give us a little more background, it should start easily even without the grid heaters down to 20 degrees or less......
Also, for sure it is a 12 valve?
Sorry did a little more searching and discovered that I have posted this in the wrong forum. Could the moderator please move this post to the 24-valve section.
WMI / VDS / VIS:1B7 / KF23D2 / WJ133069
Model: Ram 2500
Make (Manufacturer): Dodge
Model year: 1998
Manufactured in: United States (North America)
Sequential number: 133069
Get Vehicle Records & Owner Information OR Get Complete VIN Audit OR Get Certified Vehicle History Report
Body style: EXTENDED CAB PICKUP 4-DR
Brake - front: Disc
Brake - rear: Drum
Brake system: 2-Wheel ABS | 4-Wheel ABS
Curb weight: 5794 lbs / 2633.6 kg
Driveline: 4WD
Engine type: 5.9L L6 OHV 24V TURBO DIESEL
Fuel tank: 35.00 gallon / 132.5 liter
Ground clearance: 7.90 in / 20.1 cm
Optional seating: 3
Overall height: 77.10 in / 195.8 cm
Overall length: 244.00 in / 619.8 cm
Overall width: 79.30 in / 201.4 cm
Standard seating: 6
Steering Type: Recirc
Tires: 245/75R16
Trim level: Quad Cab 8-ft. Bed 4WD
Turning Diameter: 51.30 ft / 15.6 m
Wheelbase: 154.70 in / 392.9 cm
Model: Ram 2500
Model year: 1998
Brake - front: Disc
Brake - rear: Drum
Driveline: 4WD
Optional seating: 3
Standard seating: 6
Tires: 245/75R16
1ATony
1A Auto
Jul 26, 2013 09:58 AM
joebishop23
Oct 29, 2007 10:19 AM
abc4yew
15
Aug 18, 2006 11:10 PM
ricky789
May 7, 2006 11:15 AM
