Tach drops off and no o/d or lockup
So its been happening for awhile now and Ive read quite a few threads on the o/d and lockup doing the same thing but in all those threads I never seen one that said about the tach dropping off at the same time the issue is happening. Any know where I could look? Im a first gen guy so I don't know anything about theses 2nd gen trannies. Its a 96 3500 with an auto obviously tranny rebuilt less then a year ago
any way to tell for sure and or test it? sometimes the truck will work fine, other it will do it off and on and just yesterday it dropped off and didn't come back on until i shut off the truck and restarted it. today its fine
don't know for sure, when my engine speed sensor/crank sensor died my alt wasn't charging
What I meant to say... was the gauge still works lol. It doesn't happen for long enough periods of time for the batterys to die. It also doesn't happen unless moving so I wouldn't be able to test the actual alternator while it is doing it
Check that the engine speed sensor (no crank position sensor on a 12 valve) is gaped properly, the wiring and connector are intact and clean.
If that doesn't fix it replace the ESS, available at any autoparts store.
JVDodge
Jan 27, 2008 10:30 PM
BIGBEN
Jan 14, 2008 08:53 PM
