Surging/loping
Just came back from the test drive after replacing the Overflow valve and the Prefilter. So far I am very impressed, but I only went about 2 miles. After it sits all night and I fire it up cold will be the real test. The whole job went pretty smoothly. The only problem I ran into was trying to keep the new gasket on the Prefilter bowl in place, but a little rubber cement took care of it. Did find the heater bolt loose. I jumped on the throttle and released it immediately several times and it did not stall this time. Throttle response seems to be better, too. Will keep you posted. Thanks for all the help,
Mike
Mike
I wonder if the overflow and prefilter is the cause of my idle issues, the warmer the outside temp the lower my idle. (AC off) sometimes on a hot 100F plus day im idling threw parking lots at 400 rpm but as soon as the weather cools down im right back to 750-800
Have you ever checked and changed your fuel lines? I noticed the same with both of my 96 2500's. When the rubber inside the braided lines heats up it stretches and sucks more air. The best thing to do is order a fuel gauge and leave it installed so you can check the fuel pressure. Larry B's sells one that threads right on the top of the filter housing under the hood. I noticed a big increase in throttle response and power when I clean the pre filter and changed overflow but no change to idle. One other thing to check is your timing. Bump it up to 14-15* and you'll be pleased with the fuel mileage and that effected my idle. Let us know.
Its as simple as either going into the top of the pump through the afc or through the side port (large round plate with socket head built in). If you go in through side port, note you will spill some oil out of plate !!!! If you go in through afc, no oil spillage but you will have to take note of afc reference position and also camplate position, as you will have to remove the camplate to easily access the gov springs/weights.
Either way, your choice. Once in pump, rotate engine over by hand using 22mm socket on alternator nut, until one of the gov weight/springs shows up with slotted nut on stud. Take a flat head screw driver and turn slotted nut counter clockwise 1 click (you will fill the click as the nut has a indent profile on bottom side) which = approx 110 degs of rotation. Simple as that.
Now rotate engine by hand again until the other gov weight/springs shows up with slotted nut on stud. Turn out one click also.
Put everything back together in the reverse order and position as it was. Simple as that.
gpshemi
32
Jan 24, 2011 09:41 PM
rage_blue
13
Apr 5, 2009 11:47 PM
