Stripped Timing Cap P7100
Old Jun 16, 2019 | 01:36 PM
Zekerbox's Avatar
Unhappy Stripped Timing Cap P7100
I was working on my truck this past weekend. I was replacing my pushrod cover gasket. When I was reinstalling my pump and timing I was tightening the timing pin cap back down and used too much gorilla wrenching and felt a pop and now I can't get the cap tight. It gets tight and then it just pops loose. I filled my pump with oil and it just drains out of the cap. I ordered a new "cap" hoping that is the issues and I just broke the threads. I really don't want to take the pump back out as I've had the pump out and back in twice and I just want to get my truck back on the road. Does anyone know if and where I can get the "timing housing" portion that the cap threads into? It seems like the housing's top screw is some sort of security bolt that can't be removed. Some assistance would be appreciated! Thanks
Old Jun 17, 2019 | 10:32 AM
AlpineRAM's Avatar
Usually it's only the cap that gets damaged.
Even if you damaged the threads a bit you can easily fit your new cap with a bit of thread sealant and let it rest for some hours before filling with oil.
Old Jun 17, 2019 | 12:09 PM
Zekerbox's Avatar
Thanks, I ordered the new cap and copper gasket. I also contacted a local bosch repair center to see if they can source the part. My guess is that part is going to be expensive.
Old Jun 17, 2019 | 12:13 PM
Zekerbox's Avatar
When you talk about thread sealant are you talking about like some teflon tape?
Old Jun 17, 2019 | 12:51 PM
AlpineRAM's Avatar
I was thinking of thread sealing compound by Loctite for example 243 or 5400
Old Jun 17, 2019 | 01:08 PM
Zekerbox's Avatar
Oh gotcha, I have some 243 I will put some on when I get the new cap and see if it will seat the washer ok. From what I can tell the part that is on the pump is steel and the cap is aluminum. If my assumption is correct you're correct that the cap is most likely stripped/broken. It still has threads on it but they just seem loose and pop out. My thought is that the threads should be deeper, but I have no good cap to reference.
Old Jun 17, 2019 | 01:11 PM
AlpineRAM's Avatar
Those caps do not require much torque to seal, actually overtorqueing them is the way to make them leak. The threads get deformed, and don't fit anymore.
Loctite 243 and just snug with the screwdriver handle and a socket. Let the compound work it's magic, the plug will not come out unless you use the ratchet to open it.
Old Jun 17, 2019 | 01:18 PM
Zekerbox's Avatar
Yup, that makes sense. I haven't timed the pump since it was rebuilt 200k miles ago and it seemed to take a lot to get it off, so I assumed I had to gorilla it back on and was wrong. From what your saying it's more likely I was just breaking loose some thread lock from the rebuilder.
Old Jun 17, 2019 | 01:23 PM
AlpineRAM's Avatar
Either a thread locker or the corrosion forming between dissimilar metals..
VFDFireman
Jan 5, 2008 06:47 PM
sterling
Oct 19, 2007 05:32 PM
ajpulley
Jan 16, 2006 04:21 PM
jimrob
Mar 1, 2003 11:27 AM
fboese
0
Dec 10, 2002 04:01 PM
