Stripped Timing Cap P7100
I was working on my truck this past weekend. I was replacing my pushrod cover gasket. When I was reinstalling my pump and timing I was tightening the timing pin cap back down and used too much gorilla wrenching and felt a pop and now I can't get the cap tight. It gets tight and then it just pops loose. I filled my pump with oil and it just drains out of the cap. I ordered a new "cap" hoping that is the issues and I just broke the threads. I really don't want to take the pump back out as I've had the pump out and back in twice and I just want to get my truck back on the road. Does anyone know if and where I can get the "timing housing" portion that the cap threads into? It seems like the housing's top screw is some sort of security bolt that can't be removed. Some assistance would be appreciated! Thanks
Usually it's only the cap that gets damaged.
Even if you damaged the threads a bit you can easily fit your new cap with a bit of thread sealant and let it rest for some hours before filling with oil. |
Thanks, I ordered the new cap and copper gasket. I also contacted a local bosch repair center to see if they can source the part. My guess is that part is going to be expensive.
Originally Posted by AlpineRAM
(Post 3361540)
I was thinking of thread sealing compound by Loctite for example 243 or 5400
(Post 3361552)
Those caps do not require much torque to seal, actually overtorqueing them is the way to make them leak. The threads get deformed, and don't fit anymore.
Loctite 243 and just snug with the screwdriver handle and a socket. Let the compound work it's magic, the plug will not come out unless you use the ratchet to open it. |
(Post 3361556)
Either a thread locker or the corrosion forming between dissimilar metals..
