Stabilizer bar / front end shimmy / transmission
Old Apr 15, 2006 | 09:31 PM
kawi600's Avatar
Well I was hauling some dirtbikes to the trail this afternoon doing 70 on the highway and hit a bump in the road and had my front end go into an oscillation. I could feel the wheels bouncing back and forth while the truck went straight. The only thing that stopped it was to lay off the gas. Just like headshake on a sportbike. Guess its time for a new trackbar =(
Also have put about 5k on the truck since I added all these power mods and with the thrashing Ive been giving it I thought for sure the bottom of the transmission pan would be covered in metal shavings. Looked pretty **** clean though.
Might just change the oil more frequently till I can afford a trip to my local DTT dealer
Anyone here had luck installing a torque convertor and valve body onto an old transmission? Did it hold up good?
Old Apr 16, 2006 | 11:21 PM
inarush76's Avatar
If you are going to have the trans pulled to install converter, at least have trans freshened up and cleaned out before installing converter and valvebody.
Cost to do this likely won't be too much. Do it once, do it right.
James
93' Shorty
Nov 22, 2004 03:05 PM
10HAAP
Jul 25, 2003 01:14 PM
kd460
Jul 15, 2003 07:36 PM
bcb1962
Jun 24, 2003 10:16 PM
heybelle
Dec 28, 2002 12:31 AM
