Differences between 47rh and re
Old Apr 2, 2006 | 09:03 PM
Buckshotram's Avatar
What are the differences in the re and rh. Also will will lockup switches work on the rh and or ats transcommand?
Old Apr 2, 2006 | 11:03 PM
dieselhawg's Avatar
The rh is shifted by hydraulics and a shift cable.The ecm controls the overdrive and lock up.On the re the computer controls the shifts and the overdrive and lock up.The cable is only used as a kick down cable.
Old Apr 3, 2006 | 11:11 AM
Sidewinder's Avatar
I read here that one of the shafts (input or output) is also bigger on the RH. Not sure which one it was.
Old Apr 3, 2006 | 05:02 PM
JD730's Avatar
Sidewinder, I'm not sure about the shafts, but I do know that the overdrive case is different. Along with what dieselhawg said.
Old Apr 3, 2006 | 10:39 PM
cumminsdriver635's Avatar
Yep. I have also heard that one(maybe both??) of the shafts in the RH are bigger/stronger than the ones in the RE... Dont know how true this is, but its fine with me..
Eric
Old Apr 12, 2006 | 12:09 PM
Racing_Joe66's Avatar
overdrive part
will the overdrive section off a 47RH work on a 47RE unit?? i have been told it will and i have been told it won't. i just want to clear it up. as i just bought a overdrive section off a 2004 dodge 3500 4x4 with a 47RH trans and i have a 97 dodge 2500 4x4 with the 47RE trans.
the place i got it from said it will work on either from 96-06.
is this true or did he screw me over??
thanks
Old Apr 12, 2006 | 01:57 PM
Crawler's Avatar
The 47RH only came in 94-95 trucks.
If the truck that the OD section came out of is an 04 then it will probably be a 48RE.
Later,
Wes
Old Apr 12, 2006 | 06:32 PM
the guy i got it from claims its a 47RH and out of an 2004 3500 4x4. and it will work from 96-06 on the 47RE and 47RH.
can anyone else help with this???????
thanks
Old Apr 12, 2006 | 07:21 PM
infidel's Avatar
'06 uses a 48RE
Old Apr 12, 2006 | 07:47 PM
Mr. Jimmy's Avatar
The 48RE came out in 03 although there were still some 47RE's out there in the SO trucks.
Old Apr 12, 2006 | 08:10 PM
Here is how it breaks down.
94-95 47rh
96-early 03 47re
early-mid 03 and up 48re
Not exactly sure how late in 03 the used the 47re, but if it came out of an 04 it is a 48re no questions asked.
Eric
Old Apr 12, 2006 | 08:44 PM
ok thanks for the clear up. will it bolt up and work on my 97 dodge auto then??????
thanks
he claims it will and i want to double check.
Old Apr 12, 2006 | 10:32 PM
Nope. Not if it did actually come out of an 04. It "might" bolt up; but the electronics, shift points etc are way different.
Eric
Old Apr 12, 2006 | 10:49 PM
inarush76's Avatar
First of all the throttle valve cable is more than passing gear. It contributes to first two shift points, controls line rise as well as part throttle and full throttle down shifts.
Look at the OD section you bought and see if it has two tubes that are slightly protruding past the gasket surface. If it does that is a RH. The tubes are feed tubes for the hydraulic governor. Also the OD section would be longer if RH. The OD section from a 48RE will bolt up to a '97 RE, but it is important to confirm the proper OD piston shim before installing.
HTH
James
DTT builder/installer
near Dallas
Old Apr 12, 2006 | 11:20 PM
is there numbers on both of the transmissions that someone on here can decode and tell me??????
thanks
