shrinking manifold
Old Mar 13, 2009 | 12:11 PM
Clinebarger's Avatar
shrinking manifold
Hey guys i need some advise on getting my exhaust manifold off . Ive got a htt manifold ordered but my manifold has shrank to the point the bolts are bent and do not want to break them off been spaying wd40 on them but still wont budge , thanks for the help
Old Mar 13, 2009 | 12:25 PM
12v rollincole's Avatar
i might be wrong, but couldnt you heat it up causing it to expand so that it would be closer to stock size and maybe the bolts would come out easyer, just an idea.
if you have already done this i dont know of anything else.
good luck
Old Mar 13, 2009 | 01:03 PM
infidel's Avatar
Ran into this several times.
Get some real penetrating oil, not WD40 and let them soak for a day.
I use Kroil but PB Blaster is good too.
Now they'll probably come out, if not put some heat to them.
Something that has amazed me several times doing this is that as soon as the torque is off the bolts they will go straight again.
When I'm working on a rig and see bent bolts I always loosen and retorque them, bolts stay straight for as many years that I've been doing it.
Once the pressure is off the manifold won't crack.
Old Mar 13, 2009 | 07:35 PM
Tate's Avatar
If worse comes to worse, cut the manifold. It should spring open, and then you have taken the side load off the bolts.
Old Mar 14, 2009 | 09:05 AM
Dartmouth 12V's Avatar
So you are doing this without changing the manifold? Are there any problems with the gaskets not sealing or things lining up wrong once you have done this? My manifold is starting to shrink and it would be great to have this easy of a fix(yeah right, it is going to be really rusty).
Old Mar 14, 2009 | 11:25 AM
infidel's Avatar
I've done it several times since I discovered the bolts straighten out when you loosen them. You loosen and retorque one at a time, nothing moves. The bolt holes in the manifold are oblong, the bolts end up in a new place. Usually just the bolts at each end are bent and causing stress on the manifold and are the only ones that need to be loosened.
Old Mar 14, 2009 | 05:20 PM
I've done it several times since I discovered the bolts straighten out when you loosen them. You loosen and retorque one at a time, nothing moves. The bolt holes in the manifold are oblong, they end up in a new place. Usually just the bolts at each end are bent and causing stress on the manifold and are the only ones that need to be loosened.
Thanks for that information, I think that I might try it when I get a chance. Time to start hitting them with pb blaster.
Old Mar 15, 2009 | 09:58 AM
John_P's Avatar
Clinebarger:
To add to what Bill already told you, another spray product that I have used to loosen those manifold bolts is a product called "Buster." For me it works as good as "PB Blaster" but it is hard to find in some areas.
John_P
Old Mar 15, 2009 | 06:47 PM
dieselman2300's Avatar
I LOVE the smell of KROIL.
Old Mar 15, 2009 | 07:00 PM
93John's Avatar
PB Blaster and hit the end of the bolts with a pneumatic hammer. The vibration from it does wonders for losening things up.
Old Mar 16, 2009 | 10:46 AM
infidel's Avatar
Me too.
Can't find it in stores though but online it's cheap with free shipping here http://www.kanolabs.com/google/
Old Mar 16, 2009 | 10:47 AM
got some kb blaster and letting them soak thanks for the help
Mark2008
Apr 19, 2013 11:27 AM
Onemoparnut
Mar 14, 2013 04:20 PM
silkywoods
35
Feb 6, 2008 12:40 PM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
