Sensitive Drivetrain
Hey guys have a question about my drivetrain. While driving I can barely tap the pedal and my truck will act like a buckin bronc, you have to be very carefully with it. Even when you set the cruise and then hit the brake to slow down feels kinda jerky. I just had it completely re done about 15,000 miles ago, the works, clutch,syncrhos,fully splined main shaft, the full meal deal. What would cause this jerkyness. I replaced the throttle cable because it was fryed and helped very litte for awhile but that was 40,000 miles ago.
Here you go
I just went and matched up a spring from ACE, put the factory snap ends on it and installed it. Worked perfect, not bucking. It all started when I was using a GN converter on a 5th wheel and the movement from that really made it bad. with my $1.50 spring all is fixed. Left the 2 small stock springs on.
smokeum99ta
Mar 31, 2008 04:18 AM
Big Smoky
Apr 10, 2007 01:11 AM
v8440
Feb 14, 2005 10:38 PM
