Scheduled Maintenance ???
Old Feb 6, 2004 | 08:26 AM
MChevy65's Avatar
Should I proactively have the valve lash verified / adjusted or just keep driving. About 200K miles so far and no mechaincal issues with the engine - just the same old nuisance problems everyone else seems to have - all referenced here (fuel shut-off, TPS, dim headlights during warm-up, flakey fuel gauge, leaky fuel lines, spontaneous overdrive off).
I was told by a Cummins mechanic to just drive it, your more likely to induce a problem then fix one. If it ain't broke, don't fix it.....
Are there any other maintenance activities I should schedule - other than the basic, oil, tranny, coolant, filters, etc.
Old Feb 6, 2004 | 10:13 AM
Dr. Evil's Avatar
I just heard (second hand) of a Cummins mechanic saying the same thing. It's hearsay at best, so take it for what its worth. My opinion, is that if the official word from Cummins says to adjust every 24k - then you should at least look at them.
http://www.dodgeram.org/tech/dsl/val.../12_valve.html
Old Feb 6, 2004 | 10:20 AM
infidel's Avatar
I've found that after 50k that the valve adjustment on most rigs doesn't change enough to warrant checking. I recommend every 24k for the first two checks then every 100k thereafter. If you don't know the trucks history check the valves, you most likely won't have to do it again.
Old Feb 6, 2004 | 10:26 AM
ImaCummins's Avatar
What if you have 136k and never had that done?
Old Feb 6, 2004 | 01:08 PM
Dr. Evil's Avatar
You have a 24V - no need until 150K....
Old Feb 6, 2004 | 02:21 PM
ImaCummins's Avatar
What does that cost to do that?
Old Feb 6, 2004 | 06:19 PM
Pumperdude's Avatar
The #1 thing to do is tab or jig your KDP.Didnt see that mentioned."If it aint broke ,dont fix it" doesnt apply to that little sucker.
Old Feb 6, 2004 | 09:31 PM
Lil Dog's Avatar
I just did a valve set on my 12V after I bought it with 87,000 miles on it.. Wow were they ever out.. The specs are 0.010 intake and 0.020 Exhaust.. 2 cylinders had intakes with 0.016 and 3 exhaust were at or over 0.027. AFter I adjusted them (takes about an hour) it sure made a smooooth running Cummins..
Anyone who says never adjust them isn't really a reliable resource IMHO. Creating a problem by removing the valve covers?? I hope they don't do overhauls...LOL...
J-eh
Old Feb 9, 2004 | 01:15 AM
Dr. Evil's Avatar
J-eh
Kinda funny that youd hear that from a "so-called" Cummins mechanic.....
Old Feb 9, 2004 | 03:32 AM
LHartman's Avatar
I've checked with a couple shops. Seems the going rate is about $100.00.
Loren
Old Feb 9, 2004 | 08:11 AM
ImaCummins's Avatar
Thanks, that's good to know.
Commatoze
Sep 9, 2004 05:43 PM
CTDHokie
Aug 23, 2004 07:31 AM
CRXsi
Jan 20, 2004 11:33 PM
tanderson2002us
Oct 9, 2003 08:55 AM
RHC
Mar 25, 2003 06:03 PM
