Safe mods for 300hp
Old Aug 10, 2011 | 11:54 AM
braap736's Avatar
Safe mods for 300hp
I've done a lot of searching on the p-pump mods for more power but I'd like to know what needs to be done to be 300 hp roughly without worrying about EGTs. I already have 5" exhaust and a HTS built trans to handle it
Old Aug 10, 2011 | 12:05 PM
maxwellp's Avatar
I would add a Pyrometer first. The only way you will know what is going on.
Old Aug 10, 2011 | 01:14 PM
braap736's Avatar
That's next on my list but I'm just looking for simple mods to the pump that won't raise egts real high but give me some more power. Right now I can't even accelerate with traffic its so slow. I don't plan on WOT runs so would pulling the plate and turning the starwheel work? And would the afc mods be worth while for 300hp level?
Old Aug 10, 2011 | 03:40 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Move your AFC full forward and loosen (forward) your AFC star screw,15 degree timing..That would make a big difference...After that a fuel plate and 3k or 4k pump springs...That should give you aleast 300 HP..
Old Aug 10, 2011 | 07:11 PM
braap736's Avatar
Thanks, that's what I was looking for
Old Aug 10, 2011 | 07:38 PM
whiskers's Avatar
I went with a #11 fuel plate, a bit forward, Great power boost with no higher EGT's. Cheap, easy and worth the money. I think it adds 50=75 Hp. Definitely feelable.
Old Aug 11, 2011 | 12:50 AM
braap736's Avatar
I pulled my fuel plate and didn't notice much of a difference. I understand that basically a full throttle stop and I'm not holding it wide open so maybe that's why. Also I thought there would be smoke being there's more fuel but there's hardly a puff. I then loosened the star wheel just a bit which made a slight difference
anvil
May 28, 2006 12:39 AM
streetsmoker
Feb 24, 2006 03:15 PM
wtmtnterror
Apr 14, 2005 03:01 PM
hertz
Feb 4, 2005 07:27 AM
pmtg
Feb 18, 2004 01:08 PM
