12 valve with 300hp injectors?
Old Apr 8, 2006 | 04:54 PM
anvil's Avatar
has anybody used these injectors? are You happy with them
Old Apr 8, 2006 | 05:20 PM
Dusty Ratcliff's Avatar
I've got some in right now, & I like them pretty good for the $, but I'd really like something bigger, my truck seems to have a bit of a stumble that's related to the marine injectors, it's nothing horrible, but under light throttle conditions in the lower rpm's (1800-below) I notice a slight shutter, not a bad miss or anything, but still noticeable, they're a little smokier than stock, but not alot worse than my 215's were, I can't compare #'s too well between the two as I installed the 300's while putting a new clutch in & before the clutch I couldn't really get enough grab to see what the truck would do giving it everything it had, I've considered selling mine & going back with some stockers & a set of J.R.'s laser cut DV's, I'm still on the fence between the DV's+stock sticks & stock DV's+ bigger sticks, hope this helps a little, Dusty
Old May 27, 2006 | 07:24 PM
Dual EE's Avatar
I liked them a lot. I ran them w/181dv's and a aggressive plate for about a year. They worked well towing and the stock turbo was able to keep the egt's pretty much in check. The most I dyno'd was 270/755 (mustang).
I have since switched to 370's and a Dodgezilla.
Old May 28, 2006 | 12:39 AM
bmoeller's Avatar
Had some 370 marine injectors, but the DDP Stage 4s are MUCH better. More power and cleaner.
Hercules
Sep 6, 2007 12:05 AM
jpz67
Jan 1, 2007 09:20 PM
wtmtnterror
Apr 14, 2005 03:01 PM
hertz
Feb 4, 2005 07:27 AM
pmtg
Feb 18, 2004 01:08 PM
