ring and pinion help, Please
Old Jun 21, 2007 | 06:36 PM
rootremblay's Avatar
Unhappy ring and pinion help, Please
What are some signs of a bad rear end yall? any input at all please would help very much. Truck is kinda thumping at idle speed, I only notice it at idle speed. When cornering it kinda feels like a growling, the thumping feels like it is coming from the drive train directly for sure . Please any help yall???
Old Jun 21, 2007 | 06:53 PM
scottsjeeprolet's Avatar
could be your carrier bearing on the drive shaft. Mine went bad and sounded the same way. put it on jack stands and turn the rear wheels and listen.
Old Jun 21, 2007 | 06:54 PM
I had problems with that too, but I have a custom i piece now theres no carrier. thanks for the help
Old Jun 21, 2007 | 06:56 PM
So have you ruled out ujoints?
Guess you'll have to pop the rear cover and have a look.
does the housing get really hot after driving? They do get warm but a bad bearing will make it get really hot.
Old Jun 21, 2007 | 07:37 PM
it could maybe be the u joints, ever since I got the one piece in the truck in has had a teeth chattering vibration between 65 and 75, I have put maybe 5,000 miles on it like that. I also had a broken lift block pin that let one side of the axle slide an inch back (my carrier bearing culprit) I just got the axle straightened out, so all 5,000 miles were at a bad angle. do ya think the u joints could be shot that quick with the bad angle and vibrating. they are balancing it for free when I get a chance to take it back in. And Im guessin a bad (really bad) u-joint could feel like a rear end prob huh??
kingdaddy
3rd Gen All Products
Apr 10, 2015 09:27 AM
Galaxie 62
Dec 18, 2009 08:39 PM
Texaschevelle
Oct 7, 2007 10:08 AM
HaulinBut
May 12, 2006 03:06 PM
midwestdually
Oct 30, 2003 06:58 PM
