rear end pop
Old Apr 24, 2006 | 06:59 PM
cowboys toys's Avatar
rear end pop
My rear end is starting to pop when i turn curves sometimes and back up turning? What do you think it could be.
Old Apr 24, 2006 | 07:11 PM
newriverSpecon's Avatar
LSD additive? How long has it been since the fluid has been changed?
Randy
Old Apr 24, 2006 | 08:02 PM
yes it has limited slip, I just got the truck last July, am going to change it here soon
Old Apr 24, 2006 | 08:16 PM
CRSMacgyver's Avatar
Sounds like it needs the rear gear oil changed. Make sure to add the LSD additive and that should help with the chatter.
Andy
Old Apr 24, 2006 | 09:24 PM
inline6power's Avatar
mine did the same exact thing for about 2 days. took it to the shop and one of the spider gears was completely broke and 2 teeth on the pinion was in the bottom of the diff. if i were you i would take the cover off just to make sure you didnt break any teeth off.
Old Apr 24, 2006 | 09:45 PM
v8440's Avatar
I second both possibilities-just needs additive and spider gears. The first time I broke my dana 80, it did exactly what you describe, and it was spider gears. Kill two birds with one stone-drop the cover to change the fluid (and add limited slip additive), and check for gear teeth lying in the bottom of the housing while you're there. If it's broken spider gears and you catch it now, you probably won't wipe out the ring and pinion. If you let it ride for a while, you may eat them up too.
Old Apr 24, 2006 | 09:55 PM
sounds right to me. wish i would have checked mine the first day i heard it instead of driving 4 days like that. would have saved me a bunch of $$$$
Old Apr 24, 2006 | 10:52 PM
how much $$$ are we talking here.
Old Apr 24, 2006 | 11:02 PM
well i basically had to buy a brand new rear end. everything but the limited slip installed cost me 1600$$ from a good good shop. you could prob get it done cheaper if it is some teeth missing but like my dad always told me, you get what you pay for.
Old Apr 24, 2006 | 11:17 PM
talked to my brother a mechanic he is getting oil and i am changing it monday. Good thing it sits most of the week since i am in college. Thanks guys, I will keep u informed what i saw. It doesn't do it all the time though just sometimes
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
doorguy
Jun 8, 2007 06:19 AM
BigBlue
Nov 14, 2004 09:26 PM
243
Aug 12, 2004 06:57 PM
