Rear brakes, can't get hubs off?
Old Dec 15, 2012 | 08:24 AM
Puke's Avatar
REAR BRAKES
Am stuck on stands in driveway and can't get hubs off.
Today is my ONLY day until january I can do my rear brakes.
I have the new pads, but can't get the hubs off.
I did a post yesterday night in the non drive train forum but nobody responded. I'm getting desparate.
One source (friends from high school) told me I don't need to remove axels, another said I do.
How do I get the hubs off??? You guys always know the answers.
Thank you in advance.
1998 24valve 2wd auto. quad cab
Old Dec 15, 2012 | 12:04 PM
dodgebre3500's Avatar
rear hubs
Use a hammer and and piece of 2x4 and pound from the back ,it will come
Old Dec 15, 2012 | 12:25 PM
torquefan's Avatar
On a 98, the drums will just slide off. The hub and axle shaft do not have to be removed. The drum is likely just rusted to the hum.
Old Dec 15, 2012 | 12:33 PM
Tate's Avatar
Back your shoes off. If it wore the drum enough to create a sizeable ridge, you won't get them off. Otherwise, just give the side of the drum a good whack from different sides, it'll break it free if it is seized to the hub.
Old Dec 15, 2012 | 12:39 PM
SIXSLUG's Avatar
X2. This is what holds the drums on 99% of the time.
A smear of antisieze around the hub will keep the rust from binding the drum to the hub for next time....
Old Dec 15, 2012 | 12:54 PM
johnh's Avatar
Originally Posted by Puke
REAR BRAKES
i use heat either with a propane torch or acty.oxy....if you are worried about using heat, think about the heat generated when stopping.
Old Dec 15, 2012 | 01:11 PM
Robert Rausch's Avatar
If all else fails try this:
With the tires and rims removed, put one lug nut onto one stud on each side of the truck. Just put it on the end of the stud and make sure it's on, but not tightened down at all. Then get in the truck, put it in 2nd or if an automatic put it in D, give it some gas and watch the speedo go up to about 20, then SLAM ON THE BRAKES. Do the same thing in Reverse AFTER letting the drums come to a complete stop. This should loosen them right up. But whatever you do DO NOT FORGET to install one lug nut onto one stud on each side. If you don't install that one lug nut the drums will come flying off. I've done this trick many times... once I forgot to put the lug nut on the driver's side, and when I hit the brakes that brake drum went flying. It is amazing how much damage one Dana 70 rear drum can do while banging around the inside of the garage at about 25 mph. Luckily it wasn't my garage.
Old Dec 15, 2012 | 01:59 PM
Puke's Avatar
thank you thank you thank you thank you thank you
Old Dec 15, 2012 | 04:07 PM
Tate's Avatar
Only works if there is no large ridge on the drum. Been there, done that.
Old Dec 16, 2012 | 09:18 AM
Even with a ridge, if the drum is stuck tight and rusted on, this procedure will break it loose.
Old Dec 17, 2012 | 02:02 PM
infidel's Avatar
After I learned this method I haven't beat on a drum with a hammer in at least 20 years.
It's gotten to the point where I don't try any other method to get drums off.
It's worked every time for me.
Old Dec 17, 2012 | 04:45 PM
TheWaterman1000's Avatar
Tate and the other's are right. Make sure you back the shoes off the drum. I did a video on doing my 1994 Ram 2500 and put it up on youtube. I barely had to ring the drums with a 5lb much in my life.
BIGOKIE
19
Jul 27, 2013 08:45 AM
91oldranchtruck
Jan 31, 2011 09:45 AM
BRUISER
Mar 23, 2007 01:06 PM
