How do I get the rotors off the hubs?
Old Mar 23, 2007 | 09:00 AM
BRUISER's Avatar
GREAT JOB...
Now does anyone actually know how to replace the rotors.. I could not get my apart from hub??
Old Mar 23, 2007 | 09:19 AM
farmer0_1's Avatar
most rigs just drive the lug studs out and the rotor will seperate from the bearing hub. nice job on the info. i see you use the same shop floor i end up on alot. i also have a nice piece of cardboard when the weather is nice. better than picking a nice clean bearing out of the rocks. again nice work.
Old Mar 23, 2007 | 09:50 AM
Bulldog's Avatar
The lug bolts are pressed into the hub through the rotor. You can try and beat them out (big pain in the Edit) , but a press does it faster and easier. Use one lug nut to protect the threads. Once all the lug bolts are pressed out, the hub and rotor separate easily. Replace the rotor with the new one and press the old bolts back into the hub through the rotor. Again, a hammer will work, sometimes, but a press is best.
The press works best on the removing because the bolts can get quite attached to their old home and may not be amenible to being beat out .
Old Mar 23, 2007 | 10:10 AM
woodrat's Avatar
Yeah I have a "shop floor" like that one too!
big hammer and punch was all I needed to get my lug studs removed.
Old Mar 23, 2007 | 10:44 AM
farmer0_1's Avatar
i forgot i just bought a cheapy press from harbor freight 12ton. wife thinks it will keep me out of the emergency room. i told her i doubt it.
Old Mar 23, 2007 | 01:06 PM
BRUISER's Avatar
Thanks I will it..
td3620
Nov 28, 2013 07:16 AM
Puke
Aug 15, 2011 07:32 PM
91oldranchtruck
Jan 31, 2011 09:45 AM
Hummin Cummins
Apr 13, 2008 04:35 PM
MoparMarv
May 9, 2006 11:32 AM
