Question with airconditioning...
Old Mar 29, 2006 | 05:35 PM
demolition_x's Avatar
this is on a 96 12 valve. apparently the airconditioning system has a leak in it. once its charged it will last for a week or 2 and works fine but there is a leak some where in the system. just wondering if any one has had a similar problem, or give an estimate on how much it would cost to fix?
thanks
Old Mar 30, 2006 | 12:32 AM
kerryneb's Avatar
it could be any of several things... about as often as anything, the compressor seal goes out... it's near the compressor clutch. hoses could have leak, or connectors... look around for oil... with a leak that bad, you should be able to see oil.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
