power steering pump removal
Old Mar 23, 2007 | 03:18 PM
lews930's Avatar
are the pumps indexed on the vacuum pump or can I just unbolt the pump and bolt another on?
thank you
lewis
Old Mar 23, 2007 | 03:45 PM
gunracer1's Avatar
they fit into a slot, it is easy to get it right. but you need to pull the vacume pump/ps pump at the same time. then pull off the ps pump. the ps pump will not slide out the back, you need the vacume pump pulled out a bit and tilted out to get the ps pump off.
Old Mar 23, 2007 | 03:47 PM
TIMMY22's Avatar
take the whole unit (power steering and vacumn) off as one assembly.
then, separate the two.
Old Mar 23, 2007 | 03:57 PM
lews930's Avatar
never mind, I'll just keep my vacuum assist brakes
lewis
tony99
Apr 9, 2014 08:25 AM
piney103
Dec 8, 2012 07:32 PM
khsjeepr
Jun 21, 2010 01:39 PM
halo6584
Nov 27, 2008 01:00 AM
DodgeCowboy
Aug 28, 2006 08:57 PM
