Power steering removal
Old Nov 26, 2008 | 09:47 PM
halo6584's Avatar
Smile Power steering removal
Does anybody know what i got to do to change my power steering pump? The steps i need i need to change mine this weekend....
Old Nov 26, 2008 | 11:51 PM
bob4x4's Avatar
DIESEL ENGINE
Drain and siphon the power steering fluid from the reservoir.
Remove the serpentine belt.
CAUTION: Do not remove the fitting on the pump that the high pressure hose screws into. The fitting may come loose unless it is backed up using another wrench. If the fitting does come loose, it must be retightened before continuing. (57 - 67Nm, 40 - 50 lbft) If this fitting comes out of the pump body, the internal spring and valve parts will fall out of the pump and they cannot be reinstalled properly. If this occurs the pump needs to be replaced with a new pump.
Disconnect the return hose.
Disconnect the pressure hose.
Access to remove the three bolts securing the pump to the cylinder head can be gained thru the pulley holes.
Loosen the pump bracket to the block.
Remove the 6 intake plenum bolts (POWER STEERING PUMP ACCESS).
loosen the inner cooler tube clamp at the intake plenum and remove the intake plenum.
Loosen the inner cooler tube clamp at the radiator support side and remove the tube from the vehicle.
Remove the power steering pump from the top of the engine compartment where the intake plenum was (POWER STEERING PUMP ACCESS).
Old Nov 27, 2008 | 01:00 AM
2wheel-lee's Avatar
I haven't been to this forum in some time, but some things just don't change: bob is still offering very useful information.
HUNTINNUT
Jul 27, 2013 11:40 AM
piney103
Dec 8, 2012 07:32 PM
khsjeepr
Jun 21, 2010 01:39 PM
trik396
Jun 1, 2008 07:04 PM
lews930
Mar 23, 2007 03:57 PM
