popping at high rpm.
My friend bought a 96 cummins 4x4, ever since he got it, it pops at high rpm. We are not sure what has all been done to the truck, we know it has a intake, the truck smokes real good, makes ok power, but it sounds like a machine gun at about 2400/2500 rpms! anyone have any sugestions on what it could be or what/where to look for.
Been there
When i encountered this problem it was happening because i wasnt getting enough fuel to my injectors. I had this problem on my 01 24valve and on my 03 Common Rail. I only had the problem after upgrading to a larger injector that my stock injection pump could not fuel hard enough in the higher RPMs. My sugestion is to check this problem and see if it helps. In both situations I found myself upgrading to at least a FASS 150gpm pump and a "Hot Rod" injection pump. After doing this I never had the problem again.
No need for a fass on a 12 valve unless your over 6 or 700 hp, the popping could be bad timing, not enough fuel or to much fuel need to check and see what all has been done to the truck, what position the fuel plate and afc, starwheel are. Any boost leaks? When was the last time the fuel filter was changed?
i would change the fuel filter before I did anything else. If that didnt fix it, I would check the pressure, and put on a new lift pump if you need it. Then I would go to timing if it still isnt fixed.
Eric
Eric
well today it blew a lower rad hose, while repairing that i found that a boost tube from the turbo outlet was ripped. i repaired that and the popping went away and a ton of power was found. now to say that, soon after getting back on the road, another water leak! After a short ride back home on a tow truck, i tore into the motor and found that a freeze plug had blown out(the one behind the fan housing). well to say the least it is a dealer item. wont be in till tuesday. i will see yall soon
mine pops and alternates white and black smoke when it hits the governor. I know it's the gov b/c it used to do it around 2500RPM until i was able to get back in there and tighten down the springs a lil more. now it rev's to 3000 before it does it.
mine does it at 1500-1700 rpm and whe i gte into the 21-2500 rpm range its so loud i cant hear anything any more... i have had people ask me if i had a problem with the motor before...
url=http://video.thedieselgarage.com/video/63178baa-f848-4f3a-9ee9-991400e4109a.htm]Click here to see Video[/url]
bigwheels94
Mar 5, 2009 08:45 PM
cumminsdriver635
Mar 6, 2005 10:54 AM
fishin fever
Feb 22, 2004 08:32 PM
klrmark
Sep 4, 2003 09:37 PM
