Please verify method for drop valve method to find Top Dead Center
Old Mar 22, 2011 | 12:11 PM
the.hogman's Avatar
OK, I have read numerous posts that give good detail but I think this will definitively set the method. If it can be a sticky how-to, that would be great! Hopefully, I havent messed it up! Please let me know if something needs reworded to be clearer.
  1. Get the engine to compression stroke (both exhaust and intake valves closed) on #1, but before the estimated TDC,
  2. position a dial indicator on exhaust valve spring after removing all lash,
  3. tighten exhaust valve to .100 past zero lash,
  4. bar engine CW EASY till stops on exhaust valve and shows .002-.003 deflection,
  5. mark dampner clearly near reference point such as sensor,
  6. back exhaust valve lash off to zero or more,
  7. bar engine CW past estimated TDC,
  8. tighten exhaust valve to .100 past zero lash again,
  9. bar engine CCW EASY till stops on exhaust valve and shows same deflection as before .002-.003,
  10. mark dampner clearly at the same reference point,
  11. back off and reset exhaust valve lash to specs,
  12. mark dampner exactly between two previous marks = TDC,
  13. bar engine CCW well past TDC and then back CW to the new TDC mark to remove any gear lash
Old Mar 22, 2011 | 12:45 PM
Lil Dog's Avatar
Sounds right to me.
Old Mar 22, 2011 | 06:04 PM
Tate's Avatar
Looks fine. Easy way of finding rough TDC on #1 is watching for valve overlap on #6.
Old Mar 22, 2011 | 06:48 PM
the.hogman's Avatar
Thanks guys! A lot of this comes from Tate anyway...
Old Mar 22, 2011 | 08:25 PM
Lil Dog's Avatar
Hes done enough to be able to do it blindfolded. Last time I saw him do it, was like 5 minutes. Took longer to shake the paint marker.
Old Mar 23, 2011 | 04:50 PM
Tate's Avatar
Pretty much was blindfolded on that one. Stupid chevy!
BearKiller
Apr 13, 2008 06:59 PM
CR785
Aug 21, 2007 05:13 PM
adidasman23
17
Jan 30, 2007 07:06 PM
Dusty Ratcliff
Mar 20, 2006 09:39 AM
Crimedog
Apr 14, 2004 09:19 PM
