please help me with my questions
new to this 12 valve forum as i have just sold my 03 and have been in the 3rd gen forums for some time
anyway i am looking at replacing my 03 with a 97 12 valve
i would like some answers to these questions
what is the hp and tq on the 97 12 valve
how much hp will the stock tranny take as far as more power
how do i turn up the power with the fuel plate
does it have a lift pump or injection pump
does the torque converter stall as high as the 3rd gen trucks on take off
does it have a block heater
thanks for the answers to these questions
someone else may have some more input, but a few of these i know.
what is the hp and tq on the 97 12 valve stock i think llike 190 hp, 400 tq
how much hp will the stock tranny take as far as more power , double
how do i turn up the power with the fuel plate, slide it up, or replace it
does it have a lift pump or injection pump, i should know, but i dont. both i think.
does the torque converter stall as high as the 3rd gen trucks on take off, havent been in an 03, i would hope the 03 is better.
does it have a block heater,yes
depends on if you get an auto or a manual tranny, the manuals are 215hp from 96-98, the autos are a little less but not sure how much
auto or manual? The manual trans with a performance clutch will take about as much as you can throw at it. An auto will need some attention if you plan on doing some high hp mods to the truck
search on here about fuel plates and grind one
both
not sure
should have one
both
not sure
should have one
turning up the fuel is all done by getting the wrenches out, nothing plug and play on the 12 valve engines.
auto trans stock hp is 189-190 i believe, standard trans are 215 hp rating stock.
should have a block heater standard.
it has got a mechanical lift pump, camshaft driven drivers side of the truck, about 2/3's back, it has got a plunger on top of it to prime the system.
Injection pump is a bosch p7100 with a rqvk governor. it is a inline pump, extremley durable pump and takes modifications quite nicely.
MoparRiggan
Jan 17, 2006 12:43 PM
Greenhorn
Feb 22, 2003 07:11 AM
