p7100 pump problem???
Old May 19, 2008 | 09:43 PM
duallydiesel24's Avatar
hey i have a 96 regular cab flatbed dually and every time i go to start it i have to bleed the pump?the guy i bought it from did a bunch of **** to it and he had ran new rubber lines from the tank up. any help would be appreciated greatly thanks
Old May 20, 2008 | 06:02 AM
robert chilton's Avatar
How long ago where the rubber lines replaced? On my 95 a previous owner had replaced them but I still had to redo them myself. If they are a few years old they may be your problem. Also double check all the connections for tightness. It can suck air even if you cant see fuel weeping through the rubber.
Old May 20, 2008 | 11:06 AM
Baja's Avatar
If you have to bleed the pump to start the truck, you are losing prime, which means you have air leak. Finding it, however, is another story. If you have access to a compressor, use a clean rag, stuff it in the filler neck, and put in NO MORE than 5 psi in the tank. If you are lucky, you will start to see fuel weeping out from somewhere. Having another person to deal with the air while you look around will help. Other sources of leaks, the lift pump, poorly fitting filter or connections, fuel heater, return line.
Old May 20, 2008 | 04:38 PM
alright thanks i guess ill try start there for now and any other things would help but thanks alot for guys
Old May 20, 2008 | 05:56 PM
j-fox's Avatar
Check the fuel return at the back of the head.
Old May 21, 2008 | 05:36 PM
now when running the 2 new from the tank to pump and then pump to tank do u just use and rubber hose or does it have to be somthing special like size and stuff like that? thanks
Old May 21, 2008 | 11:33 PM
Fueling around's Avatar
I'm chasing an air leak. I hope it isn't the return line. That octo-piece looks expensive.
Old May 22, 2008 | 08:42 AM
kawi600's Avatar
I replaced the fuel lines too. The stock stuff is prone to rot behind the tank.
A good quality marine hose should last a long time under there.
I would start with that return hose at the IP then check the fuel pickup module for leaks.
td3620
May 6, 2011 01:29 PM
masonic-dodge
21
Dec 3, 2005 01:10 PM
mr T
0
Feb 5, 2005 10:35 PM
hvanflee
14
Oct 27, 2003 12:21 AM
jimrob
Feb 27, 2003 12:33 PM
