p7100 giving out-questions??
Old May 20, 2007 | 09:14 PM
turfguy's Avatar
hey guys; been perusing the site for a few months now & thought I would post. I am buying a 94 2wd cummins & the governor seems to be out on it. I keep hearing that most folks just replace the whole injector pump; is this typical??? $800-1300 for a pump when only the governor is bad? Isn't that like throwing the baby out with the bath water? I thought p7100's were "good for a million miles" lol. I know the pump isn't bad, just the governor. Can they be replaced easily instead of the whole p7100? Also where's the cheapest place to buy a p7100?? I don't have alot to spend; I'm just trying to get out of paying too much to fill my gas dodge to pull my trailer & get into a REAL truck-a cummins! Any help / pointers would be greatly appreciated-thanks!!
Old May 21, 2007 | 12:00 PM
kawi600's Avatar
That 94 has a 160hp pump, if you intend to mod the truck at all youll be glad you stepped up to a 215.
Old May 21, 2007 | 05:17 PM
schoust's Avatar
My tuck runs well with a little 160 pump. Honestly unless you are looking to build a Hot Rod there is plenty of power to be had with that pump. I would read up on it and just dig in,otherwise pull it and have somone go through it,or you can do as Kawi says and go for big power and buy a nice new pump that flows a lot of fuel.....
Old May 21, 2007 | 05:35 PM
torquefan's Avatar
As far as the P7100 being indestructible, they're pretty reliable, but I've seen a few fail over the years. I've sent some in as an exchange for a reman, and I've sent some in for repair. If you send it to a diesel shop for repair, they'll probably want to go through the whole pump and give it an overhaul, and it may end up being the same price as a reman but take longer.
Old May 21, 2007 | 08:17 PM
bigwhite59's Avatar
close to 300k miles on mine (knock on wood) only problem is i had a copper shim under the factory delivery valve break and cause a miss. truck just made 900 ftlbs of tq and 355 rwhp.
Old May 21, 2007 | 09:30 PM
turfguy's Avatar
so is it more cost effective to fix the governor & put it back in, or replace the whole dang thing, IP & all?? The truck only has 148k on it...
Also I want to mod it some, but if I step up to a bigger IP, how will that affect MPG? I want to retain the best mileage I can for now till this price gouging BS calms down....
Old May 22, 2007 | 02:17 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Have you asked a diesel shop how much it would cost to fix the govenor linkage?My pump has the same problem.Govenor shuts the truck down after a hard pull.I decided to go with a reman 215 pump(on order)...I checked the cost and it was close to buying a rebuilt pump..
Old May 22, 2007 | 02:26 PM
Lil Dog's Avatar
I was wondering what the outcome was DD2...
Old May 22, 2007 | 03:19 PM
Yes...After I'm done,I will have the same specs as a '98 12V.
Old May 22, 2007 | 04:15 PM
Lil Dog's Avatar
Well, you had also better be ready for a clutch...
Old May 22, 2007 | 04:59 PM
Dr. Evil's Avatar
www.usdieselparts.com has stock remans for a reasonable price.
Old May 24, 2007 | 12:26 AM
Crawler's Avatar
I used to think similarly. However, a mild 215 pump will make the same power as a twisted 160pump, but will have much better manners.
That has been my experience anyway.
Ask Jim Fulmer. He has run both.
~Wes~
Old May 27, 2007 | 02:58 PM
poHmmwv's Avatar
I am trying out Pensacola Diesel They charge 725$ for a stock 215hp, and 845$ for a 245hp. With core exchange of course.
Old May 27, 2007 | 08:17 PM
xzaq103's Avatar
IM running Pensacola Diesels "hot" pump ive had it for about a month. I like it. If i had to do over though i would just get the stock instead of the "hot" pump that is 100.00 more. just add a # 10 and at least I'm thinking it will be the same power output. Seems like it is at least. Ill know tomorrow.
Chris
Mikestowing
18
Mar 28, 2010 08:07 PM
gunracer1
May 25, 2006 04:59 PM
Jeff in TD
Dec 15, 2005 06:57 PM
HydraulicGuy
Apr 27, 2005 03:44 PM
Ripper406
Apr 6, 2005 07:38 PM
