Overflow valve adjusted
Old May 23, 2004 | 09:35 PM
DZLPWR's Avatar
Question Overflow valve adjusted
I adjusted my Overflow valve from around .400 to .500 as recomended on a post i was grazing through the other day.
Man!
It DOES make a difference in lower rpm! Thats great!
But.....now i have an annoying ticking coming from the engine, most noticable when listening through the driver wheel well or under the driver door. Is this from the overflow valve?. It has been replaced and if i remeber correctly it was replaced shortly before i bought the truck in DEC 03 to unsuccessfully cure a hard start problem. Is this overflow valve bad now since it was out of spec? I know spring stretching is for the birds, so i guess i need a new one now?
Wadaya think? TIA -Jake
Old May 23, 2004 | 10:44 PM
infidel's Avatar
For 30 bucks it's better just to replace it.
Most of the spring stretch fixes I've done have only lasted a short time.
Old May 23, 2004 | 10:53 PM
Jeremy Cusick's Avatar
Yeah, get a new one... it'll run even better than the one that you stretched the spring in. At least mine does.
Old May 24, 2004 | 12:24 AM
Dufrain's Avatar
Do you guys have a link for this procedure.I didnt see it on the DIY ram repair page.
Old May 24, 2004 | 09:27 AM
infidel's Avatar
It's simple, remove the old one, put it in a new one. Stuff a rag below so you don't lose the gaskets.
Don't bend the steel fuel line to remove it, on some trucks you have to file or grind a little off the indented spot on the head to get it out. Newer OF valves don't come with what the diagram calls a retainer, they are one piece but work just the same
Object at lower left is the oil fill cap
Buy one here-
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
toll free 888-734-7349
$24+ $5 shipping and handling.
Old May 24, 2004 | 10:38 AM
Dufrain's Avatar
So should we just replace that since the one in there is old and probably is worn out.Is there something to look for if it needs replaced.
Old May 24, 2004 | 10:50 AM
infidel's Avatar
The OF valve is just a part that wears out. Unless you have a fuel pressure gauge to monitor it you're pretty much guessing at it's condition until it gets real bad.
Symptoms when the fuel pressure is too low are: low RPM miss/instability, white smoke, hard starting, engine dies at idle and low power.
Fuel filter cracking and hose leakage if the pressure goes the other way and is too high.
Old May 24, 2004 | 11:13 AM
Dufrain's Avatar
sounds like mine is still ok but ill look into replacing it in a while just to get it out of the way.Thanx for all the advice.
Buffman88
Mar 26, 2006 12:15 AM
1320
Apr 27, 2004 11:53 AM
winner172
Dec 23, 2003 02:19 PM
Superduty12v
Nov 8, 2003 08:49 AM
bcmopar1
Nov 7, 2003 04:04 AM
