OK to take Cat. of truck
Old Dec 10, 2007 | 10:11 PM
big builder's Avatar
Is it OK to remove the cat from my 97 diesel?
Are there any side effects?
Old Dec 10, 2007 | 10:13 PM
SolarYellow05's Avatar
That's a resonator. Not a cat.
Old Dec 11, 2007 | 05:33 AM
What will happen if I take it off?
Will it be too loud?
Old Dec 11, 2007 | 08:38 AM
patdaly's Avatar
On your 97, thats a Cat, and by Federal law, all kitties need a home.
That being said, not having a kitty only has a chance of deflating your wallet, not much else. I have never heard of the kitty being a choke point unless it was plugged.
Old Dec 11, 2007 | 09:58 AM
DRam11's Avatar
When I pulled the 'resonator' off my '97 it turned out to have a grid inside. That makes it a cat. The cat was put back on and then run without the muffler to see if perhaps the muffler was plugged. It wasn't. I put a rebuilt cat on - around $280 with shipping from Smith Catalyic Converters(www.smithcat.com). It was apparent the cat provides some noise control, but I would suspect you'd be able to tell the difference in noise if you ran without it. And, as said above, government agencies get all bent out of shape if you are found running without one.
Old Dec 11, 2007 | 09:59 AM
infidel's Avatar
My experience is most cats start plugging up around 80k miles but that might change with the new ultra low sulfur diesel. I've run across several rigs whose high egt, low power problem was cured by trading the cat with a straight pipe.
Removing the cat changes the tone of exhaust at idle but does little else unless of course unless it's plugged up.
Old Dec 11, 2007 | 10:50 AM
1-2-3's Avatar
Just a plain ole guy
A 97 does NOT and will NOT have a catalytic converter. My 99 does NOT. What your seeing IS a resonator. Looks like a big soup can with an inlet and outlet pipe. I took my muffler off first and it really didn't make much diffrence. It wasn't untill the resonator went that I started liking what I hear.
Old Dec 11, 2007 | 12:16 PM
patdaly's Avatar
Charliez, you had better take that up with Dodge then.
Beginning with Jan.1, 1994 production, Catalysts were indeed installed right up to Jan1, 1998 production, when the 24V trucks came out, Catalysts were not required.
Your 99 will NOT have a Cat, our 97's certainly DO.
Old Dec 11, 2007 | 12:37 PM
DRam11's Avatar
Perhaps Charliez's pickup had it's' cat disemboweled by a previous owner. As said, '97s DO have a cat.
Old Dec 11, 2007 | 12:58 PM
winkle's Avatar
My '96 had a cat on it till I open the door one day and it ran away.
Old Dec 11, 2007 | 01:27 PM
Rampage Randy's Avatar
If Dodge didnt put cats on then somebody put one on after mine left the factory. HA HA. My 96 had a cat
Old Dec 11, 2007 | 01:47 PM
Danavilla's Avatar
I pulled the restrictive exhaust off my '98 12V, which included a factory cat, and installed a MBRP 4" turbo back. The increase in sound level was dramatic, especially when towing. I then inserted a 4" cat off a '06 and it quieted down a lot but not to the level of the Banks cat-back system I had on it before. It sounded pretty good actually, and my wife didn't complain.
Dan
Mulberryfire
Sep 10, 2009 07:27 PM
Doubleover
Apr 30, 2006 03:02 PM
Rare1
Jul 17, 2004 08:48 AM
Graphite600
Jun 7, 2004 09:09 PM
