Oil Sending Unit
Old Apr 4, 2006 | 07:05 PM
Flashpoint's Avatar
Oil Sending Unit
98 12valve where is it located. I just bought a second truck and the oil gauge drops then comes back up .Shows good pressure other than that. Im going to try a new sender and see if that works
Old Apr 4, 2006 | 07:44 PM
somis13's Avatar
its on the drivers side of the block, behind the p.s. pump, look through the fender well and you will see it
Old May 29, 2006 | 01:49 AM
Katmandu's Avatar
Question
Is the Oil Pressure gauge governed by the PCM in a truck built 11/97 (98 model) ??
If so, can the Dealer "TWEAK" the range (with a code reader or whatever it's called) so the Oil pressure can be kept from constantly dropping to zero at idle ?
Common
Aug 24, 2006 06:31 PM
Dieseldude4x4
Oct 24, 2005 09:12 AM
SammyBuca
Nov 4, 2002 09:17 AM
JASON T.
Oct 20, 2002 01:53 PM
