Oil pressure sending unit
Old Nov 4, 2002 | 08:32 AM
SammyBuca's Avatar
Limped home last night (check guage light came on a couple of blocks from home). I'm assuming that it's a bad sending unit. As I am without a manual, where is it located? I really need to get a manual......sigh.<br><br>Thanks for any assistance you might have.
Old Nov 4, 2002 | 09:13 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Oil pressure sending unit
From Dave Fritz' site www.dodgeram.org
A MUST SAVE for info.
Fuel System Components - 24-valve Cummins Turbo Diesel engine.
1. Fuel Transfer (Lift) Pump
2. Fuel Return Line (to Fuel Tank)
3. Fuel Supply Line (Low Pressure, to Engine)
4. Fuel Heater
5. Water-in-Fuel (WIF) Sensor
6. Fuel FilterlWater Separator
7. IA T Sensor
8. Map (Boost) Sensor
9. Fuel Drain Manifold
10. CKP Sensor
11. CMP Sensor
12. Overflow Valve
13. Drain Valve
14. Fuel Pressure Test Potts
15. ECM
16. ECT Sensor
17. Fuel Injection Pump
18. Throttle Lever Bell Crank and Apps
19, High-Pressure Fuel Lines
20. Fuel Injectors
21. Fuel Heater Temperature Sensor (Thermostat)
22. Oil Pressure Sensor
23. Fuel Injector Connector
24. Drain Tube
25. Intake Manifold Air Heater/Elements
Old Nov 4, 2002 | 09:17 AM
SammyBuca's Avatar
Thanks.........just found this on a previous post........Thanks everyone for for posting all this information for us poor backyard mechanics.
fourdawgn1978
Apr 19, 2006 05:27 PM
Dieseldude4x4
Oct 24, 2005 09:12 AM
easye
Nov 15, 2003 02:23 PM
