Oil Pressure sensor plug
Old May 22, 2021 | 01:15 PM
oldmutt's Avatar
5 Year Member
I am having the normal problem with the factory oil pressure gauge that drops to zero when it reads under 20 psi. I have a mechanical one so I know I have the correct oil pressure. I want to use both but I cannot figure out how to get the electrical plug off of the sending unit. I watched youtube videos and some say to pull up on the tab and others say to push on the red tabs. My plug has a red tab on each side that slides back and forth. What am I missing. I can not get this off?
Old May 22, 2021 | 09:00 PM
texasprd's Avatar
Are you trying to connect the mechanical gauge at the same place as the electrical? If so, no need - many (if not most) who run a mechanical gauge tap in at the top of the filter mount. There's a pipe-thread plug there thats easily removed.
Old May 23, 2021 | 08:33 AM
oldmutt's Avatar
5 Year Member
Oil Sensor
Thanks for your reply. I have the mechanical gauge connected at the filter. I just want to replace the electric sensor so I do not have the listen to the warning sound. I just can not figure out how to get the electric plug off of the factory sensor.
Old May 23, 2021 | 04:32 PM
texasprd's Avatar
I dont see your truck details - what year is your truck?
Old May 23, 2021 | 04:47 PM
oldmutt's Avatar
5 Year Member
oil sensor
Sorry for leaving out the details. It is an early 98. Build date 9/97.
Old May 24, 2021 | 11:03 AM
texasprd's Avatar
The connector on my '96 has the typical retainer that slides over the little triangle on the sensor snout and that you carefully lift up when removing, so it's very different from yours. From the pictures I see on RockAuto of your connector, you should slide the red tab outward and remove the connector. It looks like the tab is a sliding lock. I hope the pictures in the linked items give a feel for how far out to slide the red tab.
Best example
Another example
I hope this helps
Old May 24, 2021 | 06:13 PM
oldmutt's Avatar
5 Year Member
oil sensor
Thank You! I see the red tab but I did not know what to do with it. I will give it a try first chance I get.
Old Jun 4, 2021 | 12:28 PM
oldmutt's Avatar
5 Year Member
oil sensor
Follow up to my oil sensor plug. Well I finally got the plug off and replaced the oil pressure sensor with with an OEM one. Put it all back together and no change. So I guess the gauge is bad. Oh well you win some and you loose some.
Old Jun 4, 2021 | 02:49 PM
texasprd's Avatar
Not necessarily. PMing you with how to get a free downloadable factory service manual for the '98. Gauges are in section 8E of the manual for my '96 - should be in the same section (or close) in the '98 manual. There are some more steps you can take to determine if it is a bad gauge or another issue.
Snapper
Feb 18, 2007 10:08 AM
NoSparkplugs
Aug 6, 2006 08:48 PM
grandblanc
Feb 10, 2006 04:07 PM
rubberduck
Sep 16, 2005 10:49 AM
