Oil pressure sending unit socket question
Old Oct 20, 2008 | 04:31 PM
CTD2001's Avatar
Well the oil sending unit on my 96 was broken, i got a new one and a socket to take the old one off and put the new one on. I got the old one off no problem because it was broken. I put the new one in and tighten it as tight as i could with my hand, then i tried to put the socket on it to snug it up more, but i cant get the socket to go on straight because the new unit is not broken and the socket is to fat and hits the power steering pump. Any suggestions, do they make a slimmer socket?? Thanks
Old Oct 20, 2008 | 06:18 PM
illEatUrDuramax's Avatar
what kind of socket are you using? i just had to replace mine too and i picked up a special socket for it when i got the sending unit. i had to use an extension to reach it but it worked
its made by Lisle 1 1/16" and its got the special groves that fits with the sending unit itself. it was like 10 buck if i remember right. hope that helps
Old Oct 20, 2008 | 06:24 PM
CTD2001's Avatar
yeah, the socket i got was from napa, the socket fits on the sending unit, but the old sending unit plastic piece was cracked so it was able to move side to side, but the new one is not broken so i cant move it side to side. I cant get the socket between the power steering pump and the sending unit, not enough room for it to fit through, thanks
Old Oct 20, 2008 | 08:13 PM
Dartmouth 12V's Avatar
Are you sure that the new unit is not cross threaded? I replaced mine a few months ago and had plenty of clearance.
Old Oct 20, 2008 | 09:06 PM
CTD2001's Avatar
yeah, it screwed in by hand with no resistance at all, i guess i can pull it out and look at it. Thanks
Old Oct 20, 2008 | 09:51 PM
CTD2001's Avatar
when i have the socket on the sending unit, you can see where it is hitting the back of the power steering pump and can visualy see that the socket is at an angle. I dont get it
fourdawgn1978
Apr 19, 2006 05:27 PM
Dieseldude4x4
Oct 24, 2005 09:12 AM
easye
Nov 15, 2003 02:23 PM
SammyBuca
Nov 4, 2002 09:17 AM
