oil leak at turbo
Old Mar 21, 2005 | 12:45 PM
Txwelder's Avatar
oil leak at turbo
Came outside to see a trail of oil on the frame in the passenger side front wheel well. Open the hood and oil everywhere. Where can I get a gasket for the turbo oil return line for less than my left foot? Also, anything I should know when replacing the gasket? Thanks
Old Mar 22, 2005 | 11:44 PM
Txwelder's Avatar
Nobody has dealt with this? I cant be the only one, too many trucks out there.
Old Mar 23, 2005 | 12:46 AM
Forrest Nearing's Avatar
if you can't put your hands on one, I can put one in the mail for ya.
Forrest
Old Mar 23, 2005 | 06:55 AM
greasemonkey's Avatar
you should be able to get the gaskey from cummins. or maybe not.
Old Mar 23, 2005 | 09:02 AM
My local Dodge dealer only wanted a buck for the return gasket.
Old Mar 23, 2005 | 10:43 AM
infidel's Avatar
Sure it wasn't the vent line for the front differential that puked oil? It's under the airbox and will make quite a mess and is very common with no cure. Hard to imagine the return seal leaking out of nowhere unless you had it disconnected recently.
Old Mar 23, 2005 | 12:02 PM
that's kinda what I was thinking Bill, but stranger things have happened. might also check the integrity of the section of rubber hose and clamps on the drain tube as well.
Forrest
Old Mar 23, 2005 | 04:37 PM
Txwelder's Avatar
Well the only thing I can think of is when I disconnected the turbo from the exhaust manifold to install the pyro probe. But the line going down off the bottom of the turbo connects to a flex line so it shouldnt have torqued it. Dodge didnt have the seal so I will RTV away until I get one.
george7941
Nov 28, 2009 09:28 PM
onemoretruck
Nov 4, 2006 03:40 PM
edy
Apr 12, 2006 02:17 PM
donhov
26
Jan 6, 2006 07:29 PM
akghound
Jul 31, 2005 08:02 PM
