oil leak!!
Old Jul 14, 2007 | 09:36 PM
Ramdriver15's Avatar
oil leak!!
alrighty i have a nice sized oil leak coming from the backof the timeing cover. I ordered the seal for the vacccum pump it looks like it is coming from there, but i am wondering if anyone has had any issues like this before.
\Parts come in monday hopefully i can get it done by tuesday... any suggestions?
Old Jul 14, 2007 | 09:43 PM
clutch1's Avatar
just a gasket, you could use some of that grey cummins silicone for the leak.
Old Jul 15, 2007 | 08:47 AM
theal for the vaccum pump was only 4.35 so i ordered it, about the sme as silicone, so i figured might as well do it right.
Old Jul 15, 2007 | 09:16 AM
clutch1's Avatar
yeah its alot easier too and cleaner. for the 5.9's in the Ag. tractors the parts book dont show a gasket they show a tube of the silicone but all they have there is a cover plate so i guess thats why.
Old Jul 15, 2007 | 11:36 AM
GAmes's Avatar
Hope it is the vac pump gasket. If there is oil above it then it is the gear case gasket. If you have to replace it think about a new cam, since it has to be pulled to replace the gasket. Yes, I do have a PDR cam. One other thing. The vac/pwr steer pump assy is supported by an L bracket. At the top of the engine mounted bracket that the L bracket goes to is a bolt that supports the injector pump. Mine was missing, and my theory is the wt of the pump warped the gear case enough to allow oil to leak.
Old Jul 15, 2007 | 11:54 AM
thanks for the heads up!! Ill do the vac. pump. seal and clean all the oil off and see whats up in there, just awkward location and all so its a pain in the butt.
Old Jul 16, 2007 | 10:29 PM
jester1542's Avatar
I just replaced mine two weeks ago. I'm pretty slow and it took about 5 hrs. If I was more talented it could have been done in three. As a tip, remove the oil line after unbolting the vacuum pump and reattach it before bolting the vacuum pump back in.
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
